I guess I'll flip the pulley and order a new BX26 belt, somehow every time I read one of Mark Jacobs or David Bests posts I learn something new.Flip the motor pulley and run it as a single belt speed, it would take a Gates Tri-Power BX-26 belt. If one is using a non-VFD PM-1340GT and wants to retain a 2 speed pulley drive one needs a BX-24 and a BX25 belt, the stock belt is somewhere in between those two.
When running off of a VFD If you want quicker stops, set a higher mechanical RPM drive setting and turn down the VFD Hz. So for threading I usually run my VFD at around 20-30 Hz. There is less mechanical momentum in the drive system.
Using a VFD and flipping the motor pulley, use a BX-26 (If I recall a few people have also used a BX-27):
Stock non-VFD would need a BX-24 and BX-25:
Mark,No pulley changes for low and high speed. The stock large motor pulley to large headstock pulley splits the difference between the pulley ratios, so with a VFD running to 20-90/100 Hz should give you a spindle speed range of 50-2000 RPM using the gearbox ratios/VFD. When running an inverter style motor which goes to 120-125 Hz, using a ~2.3" pulley you get about the same speed range with more optimal motor performance in the constant Hp range.
I learn that my wallet gets lighter after reading their posts.somehow every time I read one of Mark Jacobs or David Bests posts I learn something new.
No truer words...I learn that my wallet gets lighter after reading their posts.
Perhaps this will help you - especially if you're considering a VFD configuration. I have posted speed tests of my PM-1340GT here using Mark's control package with Hitachi VFD. The first photo describes the motor/belt/pulley setup. The videos that follow illustrate the range of speeds available in Low/Low and High/High gear settings, along with the actual RPM with the VFD at 60Hz in each of the six possible gear settings. With this setup I am able to achieve 24 to 2081 RPM with a single belt position. And with the JOG function, I have sufficient torque to run a 5/8-11 tap (in a tailstock-mounted tap holder) into 304 stainless at 24 RPM using the Jog joystick for control (I haven't tried anything larger - yet).Mark,
Do you have a thread that dives into this? I am trying to decide what direction to go with for my now on its way 1340GT 3 Phase.
Thanks!
