- Apr 8, 2013
- 1,982
I'm going to be building my first rifle this winter and I'm just trying to get the best degree of accuracy that's possible from my Grizzly G4003G. I have a ground 12 inch piece of 1 inch od drill rod so I thought I would start by getting that spinning true just by impersonating a machinist. I stuck it into a 5C collet and center drilled it. Then I put the drilled end into a live center and stuck the dead end about one inch into the 5c collet. I got my DTI needle going from .000 to .001 on one end and about (-).001 to .000 on the other. I don't know if I should call this .001 or .0005 runout (on each end). Wanting to do better, I parted off the center drilled end and chucked it in a 4 jaw. After 20 minutes of doing it over and over I got the DTI reading about .0002/.0003 at the 4 jaw end. (interpolating between the .001 ticks). I center drilled it again. Putting the drilled end in a live center and about 1 inch into the 4 jaw at the dead end I got it dialed in (4 jaw) to just about nothing. Stuck the DTI on the live center end and it was STILL pulsing .000 to .001??? I put the DTI onto the live center and it was dead nutz. So, is this as good as it gets or am I doing something wrong? Could it be the Jacobs chuck that is holding the center drill? I want to fine tune my tailstock which is off about a thou or two but how can I trust readings that are hopping around? Any thoughts would be appreciated.
Ed P
Ed P
