Hello need advice My neighbor wanted me to cut off some bolts for his project. He is particular so I need to get the cuts square and a good taper on the thread tips.
The bolts are eight grade allen head cap screws 3/8x11/2 needing cut down to 3/4" . He needs a longer shoulder that is the reason for shortening rather than buying 3/4 " bolts. If they were longer I would just put it in a collet . Thought about double nutting them to use a three jaw chuck but wasn't sure if that would hold while cutting ?
The bolts are eight grade would a parting tool cut or should I die grinder cut then straighten with the lathe ?
Sorry for the newbie questions I only have four no extras so they have to be done right first try.
Thanks Ed
Thanks Ed
