They aren't real hard to make. I guess it's just a question of what your time is worth. I personally like making things like that rather than purchasing them. As far as removing the adapter goes, you can tap it out with a bar. They usually have a relief on the back end so even if you dinged up the end of it a little it wouldn't hurt it. You could put a brass end on the bar just in case.I am looking for a 2-1/4x8 nose protector. Ebay prices are outrageous! I need it to remove the 5c collet adapter on my lathe before I get it stuck permanently. Thanks Tim
