- Nov 27, 2012
- 7,866
For a cheap, easy, non-marring collet knock out bar I used a somewhere near 3' length of pine closet rod. The kind you get at a lumber yard/home repair place to hang clothes on in the closet.
It works perfect on a Southbend heavy 10, just insert it and use like a slide hammer. One moderate tap with the left hand and catch the collet and or collet adapter in the right hand.
It stays leaned up against the cabinet.
Same. Well, mine is an oak dowel, I think 1 1/4". Might make a brass cap for the end, as there is a bit of rattle-room in the 1 3/8" spindle bore. Does its job though.
Good idea. I've been using a 3ft piece of aluminum round bar that I have laying around. I've been meaning to make me one out of a piece of mild steel rod or aluminum tubing & a brass slug for the tip as that's what I have on hand.
I just went a picked me me up a 1-1/4" oak dowel. My spindle bore is just over 1.5" & they had poplar in 1.5" but the oak seemed denser. I like the wood idea, much lighter, cheaper, & I'd rather save the metal for other projects. I think I'll leave one end flat & put a radius on the other end. Thanks!
