I'm a newbie to machining, and am dithering over what to do. I started out thinking I would buy a Taig mill and lathe. Then as I read different posts in different sites, I decided I needed a bigger setup. The common theme was "get the biggest you can get, because you'll soon outgrow your machines." So I started looking at various Asian Mini-lathes and mills, thinking I would buy one, and then the other, until I finally decided on Lathemaster 9x30 and a Lathemaster LM25L, and also looked at band saws and belt sanders, because several sites said I needed those. Supposedly the Lathemaster is higher quality and bigger than some of the other Asian machines I considered. Then I thought about CNC because I love computers, but became discouraged over all the comments about needing to learn manual machining first. Then I saw all the comments saying I should hold out for a used Bridgeport because all those Asian imports are crap. Then I looked at my garage and the limited space I have and thought, where are you going put all that stuff? And you can hardly drill a decent hole in wood -- what if you have absolutely no aptitude in machining, and what are you planning on making anyway? So I started downsizing my dreams of being a machinist to the point where I am back at Taig again. I had to relook at my goals.
First, I want to learn how to make things with my own hands. Although I have used things that other people have made, I've never made anything significant involving craftsmanship. I've spent over 10 years flying jets as a naval aviator and as a Learjet Captain, 10 years as an Aerospace engineer involved with aircraft, Space Shuttle, and satellite projects, and 20 years as a lawyer, so I'm not afraid of trying something new. But I admire those of you that make practical or beautiful things out of scraps of metal, and I want to be just like you. But I don't know how passionate I will be until I do it. I know I am tired of killing trees and inking paper. Historically, when I start a hobby, I run with it. But that is only if I love it. Here, I just imagine I would love it, although it is a much greater depth of imagination that my desire to play the piano, which will never happen.
Second, I want to make models and toys for grandkids as a means of learning machining skills.
Third, I don't know where I am going from there. I would like to be a hobby gunsmith so I might put my hopefully acquired machining skills to work there. Or I might want to make knives, or pens, or chessmen or whatever. I see lots of project ideas and even specializations that look like fun, but who knows.
So, I'm back at Taig. I'm thinking that I will either decide Taig is big enough or it isn't. And when it isn't, I can buy a bigger set up then. And since this is forum with a lot of Taig, Sherline, and Sieg mini-machine users, I thought I'd ask this question. Will I regret setting up shop with the Taig to start with, and if so, why? And if you are a Taig or Sherline user that found yourself size-limited, how long did that take, and do you regret starting at the micro level? And finally, if you were trying to just learn basic machining skills, what projects would you consider starting with?
If you read this far, thank you. I look forward to reading your comments.
