WM210V replacement parts
weston1968
H-M Lifetime Diamond Member
Aug 29, 2016
121
Seems pretty reasonable if that's a drop in replacement
It is already marked as shipped, I will know I a few weeks. The vendor I bought my lathe is also contacting the factory and will get back to me. A couple of spares for a long distance part is a good idea.
wm210v tool holder post
This looks like it has the holes drilled for the protractor so it should be able to rotate.
Numobams WM210 Lathe Axle Sleeve​
Replacement spindle with 38mm bore
Main Control board
Have you taken it apart to make sure that is the gear that broke? Because there is a brass worm gear that drives the apron/carriage. Just wondering out loud.
Yes, I have taken it apart. No worm gear. The Handle is connected to a 14T mod1 gear driving the 44T part of a dual gear 44T mod 1/ 20T mod. 1.25. This rides on the rack that is very close to mod 1.25. the handle is 25mm per turn.
(14T / 44T) x (20T) x (Mod 1.25 x Pi) -> 24.989941mm per turn of the Dial.
I assume when they mill the rack they fudge the pitch to yield 25.000mm per turn of the dial.
Almost every manual has it as a 44T/21T gear. The manuals are wrong it is 44T/20T.
