- Aug 29, 2016
- 121
Threading - Google Drive
drive.google.com
This is a basic program to calculate the best gears for use on the Chinese lathes. I have ordered a wm210v. I have ordered both the imperial gears and metric gears used in the program. You can add or subtract any gears.
The program does not check fit of the gears but gives many possibilities. It shows both the imperial and metric thread at the same time. I used this for my Logan lathe and stripped it down for the WM210V.
My assumptions are spindle gear 56T and Feed is shaft thread 1.5mm.
