- Dec 8, 2013
- 2,651
Good Sir:
From the pictures in your post of the sub panel in your shed you need to move a few wires. Get a separate ground bar from SqD. It will look just like the neutral bar sans the insulating block. Screw this ground bar directly to the box. Scraping paint off the box where the bar lands is good practice also. Now move all the bare wires from the neutral bar to the ground bar. Include the big green wire, where ever it comes from. Check to see that there is NOT a screw going through the neutral bar into the enclosure. If there is, remove it. This is what is called the neutral bonding screw and should only be installed in a main service entrance panel. All other places the grounds and neutrals must be kept isolated from each other.
Have FUN, be SAFE!
His shed is a seperate building. That means that the panel in it is the building service entrance and must be bonded and grounded, with its own ground rod. He should not remove the bonding screw.
