- Jun 12, 2018
- 712
I have a PM-25mv mill and the drawbar on top has a square head. I have made some add-ons to all my handwheels so I can use a 15mm socket on my drill so I can quickly move all 3 axis to where I want them. Makes life so much easier, especially the Z axis. I also use it as a power feed since my drill has a slow enough spin and I can get a consistent feed rate with it.
I want to make a drawbar and the retention nut so I can use my drill on the drawbar also. I can turn the the drill by hand to loosen/tighten the drawbar, then use power to quickly loosen/tighten. It'll make it much faster. All I have is aluminum and 1018 cold rolled bars. I am thinking of making a new draw bar with a 15mm head on top and a new retention nut to accomodate the much larger head size.
Is 1018 good enough steel to use for this project?
