• PHISHING SCAM attempt TARGETING HOBBY-MACHINIST members. It has been brought to our attention that a pop-up survey is soliciting userfeedback from H-M members. In exchange for survey information, the user is given an opportunity to win a prize if they pay for shipping charges. This is NOT a Hobby Machinist program, survey or contest. DO NOT click through the links. Close your browser immediately and restart your computer. Clear cookies, cache and log back into Hobby Machinist. Again, this is NOT a Hobby Machinist contest or survey - IT IS a PHISHING SCAM attempt to get your credit card information.To close this notification, click the "X" in the top right corner of this box.
X-axis (NO) T-slot help needed
Suzuki4evr
Sep 29, 2017
1,031
I need to install my new x-axis power feed soon,but I have a problem. Where the
T-slot should be on my knee mill,there is a piece of regtangular bar of 20mm×10mm bolted in a 20mm×10mm slot with 3 countersink hex bolts.
Well there isn't a way I can use the powerfeed end stops as it is now,because it works with the T-lock.
I have an idea to take a wider bar on the 10mm side enough to accommodate the T and slot it for the stops to fit and bolt it to the table in the same manner as before. In other words the bar would be protruding out a bit.
My question to you is: Does someone have a better or easier way to do this?
Thanks
Michael
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter
Feb 8, 2014
9,654
Just don't use the end stops, I just don't install them. I've not used any of mine in the last 40 years. But it does require a little more attention.
Suzuki4evr
Sep 29, 2017
1,031
I did receive my DRO this Thursday that past,still need to install it,I guess it would help,but I like to use a feature or function or whatever if it is there to help operation.
JimDawson
Global Moderator
Staff member
Feb 8, 2014
9,654
Installing with a DRO really creates a conflict because you want to install the DRO scale on the front of the table where the stop would normally go. A lot of people install the DRO scale on the back of the tabel........ Bad idea, this limits your Y travel.
The only reason for the stops is to shut off the power feed in case you are not paying attention, it's just a travel limit, has nothing to do with machining functionality.
Suzuki4evr
Sep 29, 2017
1,031
That is what I was planning. ...to put it at the back. So I purchased my scale accordingly I will only lose about 22mm travel,wich is not that much. Maybe I made a mistake by purchasing a tad too short scale,but there is nothing to be done about that now. I will have to learn to live with that for now. Maybe if finances allows it in the future, I will purchase a longer scale and move it to the front,but for now it will have to do.
JimDawson
Global Moderator
Staff member
Feb 8, 2014
9,654
Not sure why the length of the scale would make a difference for the mounting position. The table is the same length front and back. :) If the scale travel length matches the table travel then you should be fine. The scale is normally not centered on the table, but rather is offset one way or the other to line up the read head with the center of travel no matter where the read head mounted.
Suzuki4evr
Sep 29, 2017
1,031
If I mount the x-axis scale at the back it takes up about 22mm and therefore my y-axis scale was orderder shorter 250mm instead of 300mm. My Y-travel is 260mm.
JimDawson
Global Moderator
Staff member
Feb 8, 2014
9,654
Ahhhh, I see the problem. In that case I think I would mount a 22mm stop block on the back of the saddle to prevent over traveling the Y. I have seen some machines with a stop bolt installed into the saddle.
brino
Confirmed Tool User
H-M Lifetime Diamond Member
Jan 2, 2014
4,780
Hi Michael,
My first thought is to mount a piece of aluminum t-slot extrusion into that slot to give you a t-slot.
It is often used for wood-working fixtures and jigs.
Lee Valley tools has one that fits in a 3/8" x 3/4" slot:
https://www.leevalley.com/en-ca/sho...rts/61986-veritas-t-slot-tracks-1-4-20-thread
and one that fits in a 7/16" x 7/8" slot:
https://www.leevalley.com/en-ca/sho...ts/61646-veritas-t-slot-tracks-5-16-18-thread
Since 3/4" ~= 19mm that makes the most sense.
If it's only used for limit switches for the power feed that aluminum track should be strong enough.
They also sell the t-nuts for those tracks.
I have seen them at other wood-working stores too (Busy Bee here in Canada).
-brino
Superburban
H-M Supporter - Gold Member
Jan 2, 2016
1,330
I would just drill N tap some holes in the existing bar, in locations that would be where you may want the stops, and mount them that way.
Suzuki4evr
Sep 29, 2017
1,031
Jim I was seriously considering to put the x-axis scale in the front just to discover that it won't allow me to use my bed locks. It was all fine up until the point I saw that if I was going to mount the scale cover that it will be totally in the way of the lock levers. Well so now I don't have a choice but to mount at the back. On top of that,remember I said will only be losing about 22mm of travel..........WRONG,with the cover on,it is 40mm,but I think I am going to make a cover that is narrower, it doesn't need to be so wide.
JimDawson
Global Moderator
Staff member
Feb 8, 2014
9,654
Extending the bed lock screws is not out of the question. :) Maybe add about 40mm to the screw length.
Suzuki4evr
Sep 29, 2017
1,031
No I don't think you understand, but I will post a picture tomorrow to give a better idea.
JimDawson
Global Moderator
Staff member
Feb 8, 2014
9,654
Ahh, I think I understand. The scale housing completely covers the lock screws. Yeah, that's problem.
That's one reason I'm a real fan of magnetic scales. 1mm thick and 10mm wide.
Here is the X scale on my mill.
Suzuki4evr
Sep 29, 2017
1,031
Yeah that's exactly the problem,but I will make a narrower cover and learn to live with it.
hman
Feb 17, 2013
2,737
I don't know if my technique would be practical for your mill and DRO scale ... but maybe it'll give you the beginnings of an approach. It's how I installed a cheapo scale to the table of my Grizzly RF-30 clone. Note that the original power feed stops are unimpeded. The wide loops of the mounts allow for cable clearance.
Suzuki4evr
Sep 29, 2017
1,031
Hallo guys.
So I kind of took brinos advice and I went to a aluminium frameworks company that is just down the road from and and this is what they made for me for R50.00 (about $3.50). Then I just screwed it in and modified the stops a bit to fit and my problem was solved. Thanks for everyone's advice and input.
AdBlock Detected
I've Disabled AdBlock
