Here is a break down of the parts to get an X2 mill converted to CNC
All prices include Shipping
Power Supply,Stepper Motors,Drivers
$384.99
5Axis CNC Interface Breakout Board V5type/Mach
$26.99
Shielded Wire for wiring inside case 2ft
$24
Non Sheilded wire for motor cables 2ft
$21
E-Stop Switch , 6 Limit Switches , 3 Motor Connectors , 110V Power Switch
$90
Misc connectors, heatshrink, wireties, ETC
$60
CNC Fusion Kit 4 with Upgrde kit for larger X-Y Table
$646
LMS Large X-Y Table (optional)
$356
Controll Case used old computer tower.
FREE
Total
$1609.00
If you are starting out i would bye the LMS High Torque X2 Mill it has a high torque motor and the larger X-Y Table so that will keep cost down a bit because your standard X2 mil is $600 and the LMS mill with the bigger table and high torque motor is $789.
So if you bought the LMS Mill total would be $2050
If you bye the standard X2 Mill your looking at $2210 with larger table upgrade but if the standard x2 will do you can get it all done for $1855 not to bad to get into CNC
