[How do I?] Yet another drum switch wiring question.
DavidR8
Staff member
H-M Platinum Supporter
Oct 16, 2019
6,595
The motor that came with my Clausing went up in smoke today.
I purchased a new single phase 1/2hp 120v motor to replace it.
I have a drum switch that was wired into the old motor but I need help connecting it to the new motor.
If that's too challenging I'm fine with just having forward but I hope we can figure this out.
Here's the motor plate:
These are the instructions inside the drum switch cover. There are four wires coming out of the switch.
I may have found my answer here:
Yes that should work for you
-Mark
Here’s the drum switch as wired.
The jumper on the right side confuses me.
You would be best to remove all the wires and start from scratch-
also, green should never be used for power, only ground
(It's a code violation at worst, confusing at best)
