- Jun 29, 2018
- 134
Looking at all the threads about wiring drum switches I feel my motor is different. It is wired for 230 volts. Only four wires coming out of the motor with instructions on the motor to swap the yellow and red wires (no longer true yellow or red) for reversing. It has four terminals , two of them for line voltage and the three others.....with two of those strapped together. That is where the yellow or red wire apparently get swapped to reverse the direction of the motor. No ground or neutral terminals ...the previous owner just connected those to the frame of the motor. The drum switch I have is a Dayton 2x440. I think I have figured out a way to wire the drum switch to swap the red and yellow terminal connections ....but if anyone has experience with this situation ....advice is welcome. Thanks in advance. Richard
