- Dec 13, 2013
- 112
I have a Enterprise el2 lathe I am trying to wire up.
I have a Hitachi wj200 VFD
The enterprise has a 2 speed motor. I had to guess which wires were the high speed by tracing them from and to the high speed switching contacts so I think I am probably correct in my estimation of which wires are which. The motor will turn very slowly.
Hopefully enough background now to the issue. When I run the VFD it goes to 11 hz and stops. If I continue for about 30 secs or so it will pop a code. I cant remember the number off the top of my head but it was due to a user parameter set number
I went over my programming multiple times and can find no errors. Now D002 which monitors current goes to 16 which I assume if correct is way over what the VFD is designed for and the motor in high speed is rated for roughly 9 amps.
I believe I either have the wrong 3 wires picked for the high speed or I may have a defective motor. I have no knowledge of how to ohm a 3 phase motor to see if anything is shorted. The motor will turn over slowly however as I stated earlier. Any other things I could have missed? Thanks JK
In addition I have no idea how many poles are on the motor I put 4 briefly tried 6 with no luck> It is not listed on the motor
