try this...sorry i forgot i had it in my contact list guess its a bit late now... jayhawkman35@hotmail.com
I think I have that email also. Its all good though, thanks.try this...sorry i forgot i had it in my contact list guess its a bit late now... jayhawkman35@hotmail.com
Well, it may not help much but the AXA or 100 Series of QC's, although they will just barely hold 1/2" square tooling, were designed for 3/8" square. Note how in your third photo, the 1/2" cutter sticks out from the side of the 102 holder. And although the three photos aren't taken so as to allow determining it, if you check the locations of the four tapped holes for the screws that hold down the cutters, you should find that the center line of the holes is about mid-way between 3/16" and 1/4" from the vertical surface that forms the back of the tool holder slot. So that the center of the screws can bear near the center-line of 3/8" square cutters and 1/2" boring bars. Going to 3/8" square cutters and cutter holders will lower the cutters 1/8" and might be just enough to get them on center.
And besides, 3/8" cutters and cutter holders are usually quite a bit cheaper than 1/2".
You were meaning 3/8" shank carbide insert holders are cheaper then the 1/2" type, right?3/8" cutters and cutter holders are usually quite a bit cheaper than 1/2".
I have an issue maybe someone can clarify. I don't think I have the right QCTP. I was under the impression that I needed a #100 AXA. The one that was purchased for me said it is a #100 AXA for 9-12" Swing Wedge Type. My issue is.. I started putting tools in the holders. Even at the lowest possible placement on the QC and holder, tool is still above the center-line of work piece. It's obviously not gonna work that way, any ideas?
I will try and get some pics uploaded shortly.
This last bit confused me until I re-read it a few times, just to clarify... Maybe I am using the wrong terminology.
