- Mar 14, 2022
- 696
@mofosheee Yep, appears to be for fuel systems.
I used oven cleaner on the outside of an aluminum model airplane engine once. It permanently turned the metal very dark.oven cleaner and then wash it off
This, water and methanol injection will clean it right up. Then you can add some boost to keep your mind off the carbon!A popular accessory in the early 20th Century for automobiles was a device that vaporized water into the intake manifold. It introduced a small amount of steam to the combustion process, which dislodged carbon from the combustion chamber.
Soaked for 24hours, no effect. Moving on to paint stripper@mofosheee Yep, appears to be for fuel systems.
Give it a shot. I put a coat on by pouring the stripper into a tray and submerging the pistons up to the ring lands and set them aside. I like to let them lay for about an hour before washing them clean with a Scotch bright pad and soap and water. You may have to reapply. I also have used more aggressive paint slippers with great success. Wear protective gloves.Soaked for 24hours, no effect. Moving on to paint stripper
