Of course you have to watch all of Clough42's videos on the ELS.Can you post photos or more details on mounting conditions please?
Clough42 Github link.
Control Cabinet
Mounting position
Servo used from AliExpress approximately $175 delivered. Looks like it's increased in price $15 since I purchased one. Delivered in 2 weeks.
Made bracket out of .200" aluminum. Drilled and tapped lower base of lathe. Pretty rigid.
Encoder mounted on approximately 1.5"x0.20" aluminum flat bar. Made a bushing so removing 120/127 tooth gear and utilizing same bolt.
Timing gears are all 40 teeth. 2 on the lathe are 18mm ID with keyways from Ebay, 1 on encoder is 6mm ID, 1 on servo is 14mm ID with keyway. They all had hubs that were drilled and tapped for set screw but I turned the hub off and drilled and tapped the center for a set screw. Belts from Ebay, 1-91 tooth (273mm length), 1-125 tooth (375mm length).
Only modification was a notch cut in bottom lip of cover.
