I made a couple of dovetail insert holders. The first one was cut on the wrong side
![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Would have been fine if my mill drill had a reverse but it doesn't so I made a second one. I tried it out but the insert kept chipping plus it hammered pretty good so I gave up on it and ordered a couple of HSS 60 deg cutters from overseas. I want this so I can make the tool rest in Harold Halls book.
I was thinking afterwards that the chipping could have been caused by flexing in the tool holder. I used some 3/4" bolts for the steel and they weren't grade 5. Don't know what they were because they were stamped with numbers I haven't seen before. They also seemed soft when machined. Maybe the inserts I used too. Don't know what they were either since they came with a set of cheap tools I got.
Also made this thing. I had to have one after someone else on this forum posted pics of one he made. Now I just need to get some decent wire for it. Mechanics wire doesn't seem to be strong enough.
And finally, a project of many days. Man I'm slow at machining stuff.
I still need to adjust the angle of the pin but I couldn't wait to try it out.
Here's a pic of a test run on a piece of scrap. 40 divisions, 4 short, then a medium, 4 more short, then a long. All done without me having to count or keep track of what mark was done last. This thing works pretty slick. I got the plans from one of Harold Hall's books. I had to alter some of the dimensions because his plans were for a Myford 7 and my lathe is bigger. There are quite a few little pieces to this thing.
