Been working on getting the new shop setup.
Last Saturday my son and I installed my Ammco 10k pound two-post lift that we brought from our old shop.
Then we started working on getting the new air lines ran throughout the shop and RV bay. I also was able to get air from the ceiling down to the mill for the power drawbar.
My son's new CNC mill also showed up last Thursday. Thanks to Matt at Precision Mathews for hooking him up.
Next order of business is the fabrication of my work benches. Then I can get the mill and lathe actually leveled and I can get back to working on projects, which have really stacked up over the past almost year now.
Mike
Mike,
The shop is turning out really nice, you have to be pretty happy with it. I like your hose reels, that is the only way to go. I mounted one on my lift as well. Mine all have filters and regulators at the connection. I am guessing you have yours at the compressor.
Hi Dave, (sorry for my ingnorance), what is for and how it work a Fire piston ?I completed this fire piston today. It's made from 6061 aluminum, a #6 O-ring, and a 6d nail. Now I need to make some char cloth to use for tinder.
View attachment 59945View attachment 59946View attachment 59947
View attachment 59945 View attachment 59946 View attachment 59947
I put dro's on my lathe and a homemade yuriys bluetooth, when I go towards the chuck I get negative reading, and when I cut dia. away from me I go negative is that standard or do I have it reversed???Yes it does (in the settings).
- - - Updated - - -
You can flip the scales (they are symmetrical, so you can turn them 180 degrees and remount). Your cable will stick from the top but that doesn't matter.
Having the reading backwards is BAD... I had a lathe that had right-handed screw on the cross feed for a year. Guess how many parts I messed up after switching to a lathe that had the right screw... One short lapse of concentration during threading and you start over
Regards
Yuriy
I'm no expert, but this is how I understand they work.Hi Dave, (sorry for my ingnorance), what is for and how it work a Fire piston ?
regards Dema
