- Jul 14, 2017
- 2,448
The 605 gave me a real workout, i thought i was done with removing broke bolts but it turns out as i took the mount it had only one bolt holding it so i had to weld on and unscrow two more bolts and cut bigger threads in the head because the old ones has stripped out, i also replace the mount, used all new bolts and lock washers, the real suprased come when i seen what was in the coolant expansion tank, the coolant look like mud, so i flashed the entire system with water 4 times with the engine running and warm and filled it with new coolent. Then i looked at my notes to see when i've changed it last and i'm lucky it wasn't worse, last full flash it had 5,5 years ago and i've driven close to 400 000 km since then. After i bleed the coolant system fully i put a sticker to remind me to change the coolant again next timing belt change time.
