2019 POTD Thread Archive
I made a vertical bracket and table for my Harbor Freight portable band saw. I can swap it back and forth in about 30 seconds and there are no modifications made to the saw.
This weekend I did a bunch of, new to me, operations, and had to make a few different tools, in order to get to my end goal. So I started out deciding to make a tailstock die holder. I recently made a boring bar holder, posted earlier in this thread, and figured this would be a good project to do my first boring operations. Turned down some 2" 6061, knurled, and reamed (also a first for me) it, and finally got around to boring something.
Turned out very nice, at least for what I was expecting.
After making the body of the die holder it was time for me to turn my attention towards the tailstock arbor. I sat and thought it out, probably way longer than I needed to, and decided that I should turn it between centers, if I want it to be concentric. However, this is another thing I've not done before, nor was I equipped to do so, so i set out to make a couple of new tools...
I needed a straight shaft dead center, because the dead center I have is mt2 and my headstock is mt3, so I needed to hold it in the 4jaw. I also made a lathe dog, inspired by someone elses inquiry on this site as to "what this clamp is specifically for ", I didn't know, but after others responses, it made perfect sense, and I was going to need one.
Anyways, after making those tools, I was all set to turn down some .75" 12L14 to .500" and cut a mt2 on the opposing end.
It worked out great, and the die holder fit it perfectly! Slides and spins great, but I dont notice even the slightest wiggle. All in all, a great weekend in the shop, and I learned a ton along the way, thanks in large part to all of the great members of this site! Thanks for looking, and thanks for your help and inspiration!
-Wayne
Neat idea! Almost wish I didn't already have a vert and horizontal bandsaw....almost!;)
Wayne, your die holder is very similar to the one I made some years ago. If you need the smaller size, you can bore it into the other end. Works just as well.
Nice work.
Another little clean-up project that has been sitting on my books for a long time. I hate to admit it, but I started this one all of fifteen years ago. Then parents started dying and estates needed to be settled, so here I am finally getting around to putting the thing back together.
It's a forge blower in case you haven't figured that out yet. Made by Canedy Otto, a "Royal" Western Chief from around the turn of the century (I think). No stand with it, and when I bought it there was some damage to a few of the screw bosses as well as a particularly offensive green and black colour scheme. The crank handle was also reduced to a stub and missing the ball counterweight. But aside from that, it seemed to work okay.
When I tore it all down the insides looked really good. Hardly any wear on the gears or shafts. And there was my first surprise: one of the gears was not metal. It's like a hard rubber, and after a bunch of head scratching I determined that this was what Canedy Otto called their "whisper quiet" gear train or something like that. Basically one synthetic gear intermixed with the regular gears to make a quieter running train. I can't put my hands on the ad where they talked about it, but I may still have it in a file somewhere. That's what happens when stuff drags out for so long.
288060
288061
My second surprise was the paint colour. I knew the green was wrong from the get go, but I wasn't prepared for the traces of burgundy with gold letter highlights that I found underneath it. But I guess if you were offering a model called "Royal" that'd be one way to make it distinctive. They picked out the fan, visible only through the side intake hole, in red.
Here's some of the body castings getting the new burgundy colour. There was enough original left for me to get a pretty good match, and even though in this picture it looks a little bright the colour will darken in as it dries.
288062
288063
The fan needed a bit of balancing I guess, so there's a small tab of lead riveted on to the end of one of the blades. You can barely make out faint remnants of the red paint around the rivet heads.
288064
I happened to have this brass stopcock in my drawer of salvaged bits. It's not far off the proper vintage and a dead ringer for the oil drain cock that originally came on these blowers. 1/8" national pipe thread, it fits perfectly. For the oil filler cup on the top I ended up turning one up from scratch. Even though I'm not going to be filling the gear case with oil any time soon, I want everything to work like it should for anyone who might have it after me. Still haven't made myself a knurling tool yet so I just cut fine grooves around the top of the cap using the lathe. It goes pretty fast, especially in red brass.
288065
288066
288067
I decided to repair the existing crank handle rather than making a completely new one. The original is cast and has an elliptical cross-section which I figured I could make easily enough on a small length but not so easily on a longer length. I was able to rough out a lot on the shaper, and the rest I took care of by hand.
288068
After debating several methods of joining the new piece to the old crank, I opted to make a hollow sleeve to bridge the joined sections. I got a pretty good slip fit, then used JB Weld to hold all three together.
288069
288070
Turning the ball was a bit of adventure as well, actually that's not true, it was tedious more than anything. I really need to make a ball turning attachment sometime. And for the through-hole, lots and lots of filing.
288071
288072
And that's pretty much all she wrote. I turned a new handle from a scrap of black walnut I had lying around, put it all together onto a stand, and set it in my living room for now. I'll sell it one day, or give it to some deserving party when the time is right. The odds of me running a coal fire again where I live are pretty slim, and I have a new propane forge that I've never even fired up yet. So for the moment the Royal Western Chief is purely eye candy, but it's still better than TV!
288073
288074
288075
288076
As always, thanks for looking!
-frank
Nicely done Frank with that much effort it belongs in the living room.
I rebuilt a Thompson blower made in Grand Bay NB. Interestingly it had one brass gear in the train. The oil fill instructions on mine say "Fill With Good Oil" guess they didn't want the bad kind.
Greg
I decided to machine a jackshaft for the saw conversion. The idea is to have extra strength in the middle of the saw. Here is the video
My weekend job was to replace both front wheel hubs on my 07 Cobalt. At least it did not snow on Friday and Sunday when I was doing the job. Took about 40 minutes per side. My only problem was my one extension for the impact gun was a couple inches too long, really needed a 4” not a 6” extension, but by placing the gun inside the engine compartment for the driver side all was good. No longer does the car make that horrible buzzing sound!
Pierre
Today i continued working on the Little Niva, and i think i've opened myself a can of worms, i know about the front panel rust issues and bad repairs, but the front wings except the upper lip looked good, but i decided to remove some cracking paint and found this mess. The passenger side is gone, every few inches there's a hole, the drivers side may be saved. But i may not be able to find replacement wings and cutting them from another rusty car may be too much work so i may be forced to do the same as the back wheel arches, tomorrow i'll phone around to see what i can find, is not the welding, is the body work after that i hate doing.
288242288241288243288244288245288246
Finishing a simple project today. It be a while before it makes it into video. My sister in law wanted a wall bracket for her hair dryer and curling iron. She seen Chris’s hair dryer bracket and asked me to make her one for both.
this is the one in our house
