- Jul 14, 2017
- 2,448
Last couple of days i've been very busy, but i did managed to do some work on the Little Niva, but because i was working on it past midnight i had to keep the nose down so i did mainly mechanical work, started with draining the oil from the front diff, gearbox, transfer box, rear diff. Then i continued disassembling the drivers side suspension, and removing the axle from the diff, then i moved over to the other side, this side is more difficult, there is more rust and even more bad repairs, i broke one wrench and couple of bolts snapped off, but after couple of hours i managed to remove the axle from this side as well, i'm pretty sure i'll have to change couple of oil seals, because i drain just under 3 liters of gear oil from everything and there should be around 5 liters.
