this has already been posted but it was awhile ago so here it is again
The designer sat at his drafting board
A wealth of knowledge in his head was stored
Like "What can be done on a radial drill
Or a turret lathe or a vertical mill?"
But above all things a knack he had
Of driving gentle machinists mad.
So he mused as he thoughtfully scratched his bean
"Just how can I make this thing hard to machine?"
If I make this perfect body straight
The job had ought to come out first rate
But would be so easy to turn and bore
That it would never make a machinist sore
So I'll put a compound taper there
And a couple of angles to make them swear
And brass would work for this little gear
But its too d*mned easy to work I fear
So just to make the machinist squeal
I'll make him mill it from tungsten steel
And I'll put these holes that hold the cap
Down underneath where they can't be tapped
Now if they can make this it'll just be luck
Cause it can't be held by dog or chuck
And it can't be planed and it can't be ground
So I feel my design is unusually sound.
And he shouted in glee, "Success at last!
This godd*mn thing can't even be cast!
