- Feb 28, 2021
- 251
TIL that they sell APT retro kits for older q-jets. Prolly would have done this had I known, but now it's on the "maybe next time" list
Fuel in the bowl, because my assumption was faulty(and that valve will seal to vacuum when the FLOAT holds it closed, who knew). Accelerator pump was wonky indeed, need to hone the well and get another gasket on there, so she needed to come apart anyway. Going to Chem dip this beast since it's off anyway and blow out the passages best I can. I'm a little stumped as to why fuel ain't getting from the bowl into the manifold, but I'm pretty dense on this topic and most of my assumptions have been bad so far.Been working way too much, so even though I bolted the q-jet back on weeks ago I didn't get time in to troubleshoot what wasn't working. Bowl wasn't filling, needle valve is stuck closed.
Beast runs fine when the bowl is primed, but shortly leans out and dies. Cracked the filter housing and fuel got that far, so clearly the pump was working, vacuum tested from the filter housing and it proved the valve was closed. Triple T technology (tap-tap-tap) had no effect. Tried with a little air pressure instead, no joy.
I had bench tested this with vacuum (upside down)when I put the valve in the seat after rebushing the throttle rods, but something must have bound up in final assembly.
Gotta pop off the air horn again. This time for sure
Fortunately the carb was running fine before I rebuilt it, so all fault is mine, but she's clean.Hopefully all the alcohol jelly and sludge has been cleared out.
I suggest getting this book.
Pierre
I grew up on EFI, and it's essentially binary in most components, so things are either working or not working. Carbs are analog so two or more pieces kindasorta working seem much harder to diagnose.Back in my day, it was a necessity to know Rochesters. And if you can't make a Holley run, then you don't really have a feel how cars work. Carter is like a Rochester Lite. Then there's Mikuni and Weber if you ever owned a car from somewhere other than Detroit. I spent so much time on carburetors, but none of the books or parts kits I've amassed are useful now. I pulled the last carburetor out of a vehicle I own this year... because electronic fuel injection is king! Carbs mix the fuel perfectly sometimes, based on the metering circuits idle, main, enrichment, and acceleration, but EFI does it perfect all the time. And don't get me started on distributors. Ahem. That's all I'm gonna say about that.
