- Feb 28, 2021
- 251
Pulled off the rear line at the combo valve, opened each bleeder valve in turn and blew ~24 psi through with no problem.
Combo valve wept appropriately as well, so no constriction there, or at least not at atmospheric pressure.
Low vacuum at LR pulled fluid eventually, with only tiny bubbles, so that seems OK
RR seems to have a constriction or sum'n, will have to take another look for kinks, etc in the cold light o' day and re-evaluate.
Also noticed differential is leaking, which will require at least LR line to be removed to install a new gasket, so going to fab new lines for both sides while I'm at it.
