I'll ask these two questions together because I'm horrible at rabbit trailing. The current goal is to remove my compound. I need the adapter and don't have a mill. I do have a drill press, and my next door neighbor has a mini mill. I can use it but probably not 40 hrs worth of machining.
I'm considering using this to justify a 4-jaw chuck as I don't have one. One thing I see about the 5-inch chucks is that the jaws will stick out enough to hit the ways. But does it actually hold bigger work than a 4" opened to its max? Does anyone just sell the part? (Not that I've seen).
Is removal substantially better than just locking it down? (another common mod) Does an 0XA QCTP negate the benefit of "solid tool post?"
