I have an AXA 250-111 wedge type tool post and wondered if a 250-202T holder will fit. The reason is this; I have a 3/4" MWLNR2020K08 that I'd like to use so that I can use the WNMG0804 inserts. TIA, Kent
I have a BXA and bought a BXA holder to use a 1" parting blade in, I believe I can also buy one for a standard 3/4" and 1" tool.I have an AXA 250-111 wedge type tool post and wondered if a 250-202T holder will fit. The reason is this; I have a 3/4" MWLNR2020K08 that I'd like to use so that I can use the WNMG0804 inserts. TIA, Kent
This is fairly common.Or, could you cut down the tool shank?
^^^^This^^^^Or, could you cut down the tool shank?
Or you could increase the 1/2" capacity of the AXA toolholder to 3/4" with a carbide endmill. Buy a cheap chinese one, modify it and then you have one for any 3/4 tool you may need to use.Or, could you cut down the tool shank?
I've done this several times. Reducing the shank of the tool would be my first choice.Or you could increase the 1/2" capacity of the AXA toolholder to 3/4" with a carbide endmill. Buy a cheap chinese one, modify it and then you have one for any 3/4 tool you may need to use.
