- Jan 2, 2014
- 8,852
Whoa, not sure why those photos are so big?
That's okay, it easier on my old eyes!
-brino
So through a very extensive google search I think I've determined its a Model 8041. Which my luck gives 0 results for parts on ebay or otherwise and very little help from Clausing Industrial... Ill be on the look out for head cover, change gears etc.
Time to start making parts. I can't remember if you have a mill or not. If so many parts can be made on a mill. A head cover made from aluminum or even fabricated from fiberglass. If you end up not finding change gears, you can make them on a mill. (I've done it using a HV rotary table, tail stock, Chinese gear cutters and a broach. Not all that hard.) My lathe has 3phase 3HP and I don't think I've ever used all of it. A long time ago I ran tools on a home made rotary phase converter. Worked fine for several years. A used 3 phase motor about 50% larger than what you need to drive, big capacitor(s) a couple of switches, an enclosure.Ill be on the look out for head cover, change gears etc
I've got a Clausing 8520 that I just got running, still needs the gibs adjusted and a learning curve program... I plan to upgrade my membership here so I can use the For Sale section and pick up some much need tooling and instruments. I feel comfortable making the gears, I've been watching This Old Tony for years now and feel like a DIY expertTime to start making parts. I can't remember if you have a mill or not. If so many parts can be made on a mill. A head cover made from aluminum or even fabricated from fiberglass. If you end up not finding change gears, you can make them on a mill. (I've done it using a HV rotary table, tail stock, Chinese gear cutters and a broach. Not all that hard.)
