A lot of people are singing the praises of Evaporust (which I agree with, none better) on a thread supposed to be about home brews so I'll join the mob. But on the sub-topic of insect poison.
I am surrounded by rice farms and the mosquitoes out here are unbearable. Before moving here I thought mosquitoes were mosquitoes were mosquitoes. Turns out there are different types, just like there are different types of cats. The different types have different sizes and temperaments. What I had known all my life were the "house cat" type of mosquito. What we have out here are Lions, but their attitudes are more like that of the honey badger. They are called "Shaggy Legged Gallinippers." They are around an inch or longer and have a mean streak a mile wide. They will fly through a black cloud of citronella smoke to get to you, and you can smack them out of the air (they're big enough for you to see and hear the impact) into the ground, they will get right back up and fly straight at you.
There is no "safe" or "natural" cure that is effective for these things. At least not that I've tried, and I'm pretty sure I've tried them all. I hate to use anything that can impact bee populations, but I do anyway, because to do otherwise would mean my property would be useless for several months of the year. You cannot get anything done outside when this scourge is in full swing. There will be a literal cloud of them at the front and back door, and as soon as you open it, they get sucked in and attack. Those that don't get sucked in, follow you from the time you walk out, and torment you wherever you go. This is what it looked like after I sprayed the first year; these were swept up just from my 4'x6' concrete landing outside my front door:
I rigged up a sprayer to spray for them. Not your typical hand pump sprayer, and not even the "professional" backpack sprayer. It's a 55gal drum connected to a gasoline powered pressure washer with a turbo nozzle, that I move around with my tractor.
I spray the whole property with this setup (2.5 acres) paying special attention to the areas known to be hot spots for mosquitoes.
I do NOT spray the rose bushes or any other flowering plants, and I keep the lawn cut regularly enough that no flowering weeds have a chance to grow. The last thing I want is bees getting tangled up in my mosquito defenses. The next day after I spray, no mosquitoes. This lasts about a week, then they start gradually being replaced by younger immigrants, but just at a trickle, and the number is manageable. I've never needed to spray more than twice in a year, and it seems like every year there are less.
This or
this is the stuff I use; which ever Tractor Supply has in stock when I go; either one works as well as the other but the first one leaves a milky residue on the house and cars while the second one dries clear like water. If you're going to spray this stuff, please be aware that it's absolutely apocalyptic on the scale of little critters. It kills them all, even the beneficial ones. It kills crawfish, and if you let it get into ponds or streams it kills fish too. It kills ticks and fleas which is awesome if you have pets, but it can kill your pets too, so don't let them out until it's had a day to dry. It kills mud daubers, wasps, spiders, everything.
Please be responsible and do everything you can to avoid killing bees!
