- Mar 20, 2014
- 418
My humble contribution:
Modular Machinists Organiser Tray System by GreatOldOne
UPDATED 22/06/20 Trays to hold standard 5C & ER32 collets plus plain trays of various lengths - modular, print as many as you need and keep them together with the bowties. Each rack has a label slot so you can put a size label in for easy collet finding (so long as you put the collets back where...
www.thingiverse.com
Milwaukee Tool Hangers by GreatOldOne
Simple brackets to hang Milwaukee Fuel 18v tools on the wall. Print, screw to wall, hang tool. tool hanger V2 - good for the multi-tool wider tool hanger - wider version of the V2 part, good for the 115mm angle grinder Jigsaw hanger - sized for the body-grip jigsaw
www.thingiverse.com
Wiha Screwdriver Rack by GreatOldOne
Rack to hang Wiha Soft Finish screwdrivers - I have a set of 12: 3 flat - 3.5, 4 & 6.5 2 Pozi - PZ1, PZ2 3 Philips - PH1, PH2, PH3 4 Torx - T15, T20, T25, T30 Sized for these, in that order. The rack is in two parts to accommodate it on the print bed. Print both. PT1 will accommodate the flat...
www.thingiverse.com
