- Dec 9, 2021
- 735
Lack of the quick change gearbox is a big negative for the Atlas. The positive is that the Atlas will be easy to sell and if you bought these items for a good price, you should be able to flip it and perhaps something else to fund a better lathe. For your purpose, you really should have a quick change gear box.
A late Atlas 12x36 with the 1/2" thick ways is a major step up from the 6" Atlas. They still are limited in power and rigidity, but can do decent work, if you are patient and don't try to take heavy cuts.
You will have to step up to a Clausing or South Bend to get to the next step up in US quality machines, but there is a big jump in price.
It sounds like your experience with imported lathes is limited to the bottom end of the quality range. Stepping up quality level of imports results in much better machines, and they have modern features that will make them more productive.
I have done lots of good work on an Atlas QC42 (10x24) lathe. It has the thin (3/8") ways, so I can't take very heavy cuts. It cuts dead straight and I have a 3/4 HP motor on it, so power isn't the limiting factor. It has made or saved me enough money that it has paid for itself many times over.
If you go with a light duty small lathe, remember that you can rough out work on the big lathe, then do the finer work/fits/finish on the smaller lathe. Just leave enough meat to allow for runout from 3-jaw chucks.
