Bandsaw problem
MrWhoopee
H-M Supporter - Gold Member
Jan 20, 2018
4,193
Before anything else replace the cylinder. It all may be a simple matter of too much pressure.
jwmay
Dec 3, 2017
1,382
What kind of blade are you running?
Grizzly blades mostly. 18 tooth rakers I believe. I wanted something with less TPI, but they weren't offering them. I can't tell you about the other two, but I'm fairly certain the last one was high speed steel. I did buy one Olson bimetal blade as well, because I thought I remembered someone recommending them.
jwmay
Dec 3, 2017
1,382
Yes I agree. That's what I've ordered. Well...at least that's the TPI I ordered. I didn't check those other two specs. Doh!
C-Bag
Ned Ludd's bro
Feb 9, 2017
3,848
I have basically the same saw. My guide bearings were worn out also, pretty cheap on ebay. The down feed cylinder should be re-buildable, and it could be that just the bleed valve is bad.
The guide bearings are the only parts I’ve had to replace on my 4x6 in 40yrs of service. The worn out ones were free but rough under pressure causing the jump and bump. Replaced them at least 35yrs ago and never had a problem since.
jwmay
Dec 3, 2017
1,382
Seems like the down feed cylinder replacement solved it. I didn't change the blade yet, but it's a night and day difference as far as how the saw acts. $144.00 well spent.
woodchucker
H-M Supporter - Silver Member
Nov 25, 2015
4,391
really, boy I was betting it was something else.
glad it worked.
AdBlock Detected
I've Disabled AdBlock
