Is this an application where leather would have been used? I agree after closer inspection it definitely could be leather. I'll try soaking in clean oil.That looks like a leather seal to me. A search for leather cup seal turns up some options. McMaster has some leather seals, but I didn't see any cups like yours.
Edit to add that if it is leather it can probably still be used. Soak it in some clean oil and find a way to hold the lips of the seal spread out a bit....Leave for a few days and Robert is your mother's brother....
Bottle jacks often work a pressures higher than O-rings are rated for. Some work at a maximum of 10,000 psi. You can calculate the pressure by calculating the surface area of the piston (1/2 the diameter of the piston x 1/2 the diameter of the piston x 3.1416) (phi x r squared) Then divide this number into 24,000 (number of pounds in 12 tons).Or do you think i could just groove the poison and use an oring?
Please forgive me but i don't understand your Calc. Is phi suppose to be psi? If so, the i just solve for that right? Is it 1/2Dx1/2dx3.14 or just 1/2Dx3.14? Thank you for the comment regarding lifting equipment. I don't think i will proceed with this regardless of how the Calc turns out but i would like to know for my own knowledge. Thank youBottle jacks often work a pressures higher than O-rings are rated for. Some work at a maximum of 10,000 psi. You can calculate the pressure by calculating the surface area of the piston (1/2 the diameter of the piston x 1/2 the diameter of the piston x 3.1416) (phi x r squared) Then divide this number into 24,000 (number of pounds in 12 tons).
90 durometer O-rings are pretty tough when used with an appropriate back-up ring. If your psi calculates out to 2,000 or so, you can go to a good seal supplier and get their recommendation. Many will not be willing to supply anything but original parts for lifting equipment.
I think leather would have been the most common seal for this sort of application pre-war. I know it was used in hydraulic cylinders, water well pumps and other applications well into the '50's at least.Is this an application where leather would have been used? I agree after closer inspection it definitely could be leather. I'll try soaking in clean oil.
