Probably stay raw. The only stuff I have found that is actually any good is pretty expensive and this project is already way over budget. So I don't see spending the money.Will that remain raw concrete or will you seal it?
Yep. Once they get it dried in.Electrical next?
I have metal sheeting that will go along the inside of the walls. No barrier between the insulation and the exterior walls. Kit didn't come with anything.Nice poor! I'm concerned about the exposed insulation. How are you planning to address that? Also, did you use any kind of radiant barier on the outside of the insulation, or was int one sided - just the white plastic on the inside?
I can offer little but my envy. 26 years ago, I built my shop which is not comparable to yours and is only 24 x38'. It is still under evolutionary development. My only regret was not having done an epoxy coating. I did have the concrete people put a "sealer" on the floor which interferes with recoating. With a clean RAW concrete floor and with no way to see forward to an epoxy coating I would suggest using a roll on concrete paint like Sherwin Williams and others offer. Even sweeping chips is SO much less work and the inevitable oil spill wipes up without stains. It is possible to re paint worn areas. I have half my floor done with the paint which hasn't adhered as it should due to the crappy sealer the concrete people put on but has been mostly on there for 20 years. The original sealer melts with solvent spills or application. I would pay to have the floor ground and coated now but moving the fixtures and machinery makes the prospect impractical. I'm not criticizing your decision, just relaying my own experience.Probably stay raw. The only stuff I have found that is actually any good is pretty expensive and this project is already way over budget. So I don't see spending the money.
So how does the Staples ad go? Something like "Well, that was easy!"Finally a shop floor. 53.25 yards of concrete.
You are probably right.As soon as you get it dried in you will not have any rain for months.
