- Jan 22, 2011
- 8,031
the idea of storing electronic copies of all documents is a good one. I'm not convinced that "As Seen On TV" scanner is as smart as they want you to think. I believe you manually have to enter a lot of the data to make it a searchable database, as they present. OCR software just isn't intelligent.
I have a system of sorts where I assign every job that comes in a number, and create a directory (folder) that will eventually contain every document associated with doing the job. That means a quote from the beginning, PO, a drawing, all MTR's, PO's for purchasing materials and at the end, a cost analysis for the job, sort of a P&L on a job by job basis. That helps me determine how well I did or didn't do on that job. I do not cost out every expense on a job basis, such as misc tooling. It's not practical in my case to buy a box of inserts and try to cost out how many edges or inserts I wore out, or how many times a drill was sharpened, etc.. Unless it is a special piece of tooling that had to be bought for a job, and I need to remember that next time the job comes around (if it does), it goes into General Tooling Costs.
Electronically, I can search the DB by date, Customer, PN, or PO. My system is more oriented towards the shop side of things than the accounting side.....a weakness that I should someday address. Quarterly, I still have to do some manual work of tracking Invoices and COGS, that sort of thing. Since I don't do work for the general public, I collect no sales tax....my customers are all resellers. I still file a zero taxable sales report, however. There is a fine for not filing at all, even if you collect nothing.
I'm getting sidetracked....sorry
