- Dec 26, 2015
- 2,080
Dave L.Attached are a some pictures of the backer board being made. I will post some photos of the first project I used the backer board for in the next posting.
Thats a neat idea! I found a cheap-ish plate of 9x12x1 or so aluminum and used that. I actually 'oopsie' marked it not long ago, so I probably have another facing op coming on it soon.@Aukai , @ErichKeane
I made a poor man's fixture plate, but I wanted it to be a consumable backer board for small parts and did not need the precision of your nice fixture plate. So I made it from a piece of scrap 1" thick Nylon that I had laying around. One can tap the holes, but don't really need to do so as machines screws can be driven right into the drilled holes. CNC drilled all of the holes as well as the counter sunk holes for its clamping to the table. When it gets cut up, if it does, it can easily be resurfaced. At the attached posting are some pictures.
Dave L.
Cool. Yea, I can see the benefit and the benefit is how you use it with a small or large fixture plate. Whether you have 1/4, 3/8, 1/2" holes and pin locating holes or how intricate your hole pattern is I guess it really doesn't matter that much.You can also do the reverse - mount a smaller fixture plate in a vise to be able to clamp unusually shaped parts. This particular mini-fixture plate is from Saunders:
View attachment 433025 View attachment 433026
Aluminum is nice since you can re-finish it easily enough by running the mill over it. Otherwise I suspect is the weight of the thing. Smaller mills already have a hard time moving around a 50+lb vise, adding a huge steel plate would probably make the table tough to move.Cool. Yea, I can see the benefit and the benefit is how you use it with a small or large fixture plate. Whether you have 1/4, 3/8, 1/2" holes and pin locating holes or how intricate your hole pattern is I guess it really doesn't matter that much.
I'll head @ErichKeane advice and buy or farm it out to someone with a CNC if I try this out. Seems most are in aluminum, or softer material, any reason why not to have one made out of thick steel?
Have a look at this fixture plate from Saunders. The Tormach 1100 has a table about the size of the mills we've been discussing here. That plate in 6061 aluminum is $800 and for all the work involved, that's a bargain IMO. The same plate in 7075 is $1200, and in 4041 is $1600. I would not want a plate this size in 4041 if I were thinking of moving it on/off the table frequently because of weight.Cool. Yea, I can see the benefit and the benefit is how you use it with a small or large fixture plate. Whether you have 1/4, 3/8, 1/2" holes and pin locating holes or how intricate your hole pattern is I guess it really doesn't matter that much.
Reminds me of my magnetic SS optical tables I use to have. 10'x5' with 1/4-20 tapped holes on 1" centers!Have a look at this fixture plate from Saunders.
