4
4GSR
Forum Guest
Register Today
If you don't support the head as you are tilting, it can catch and strip the teeth. And I agree, they probably didn't have the bolts loosen enough either. I try not to tilt the head. I have a all angle vise that comes in handy when I need to cut some sort of angle. Now, I do nod the head once in a while and haven't had a problem with this. Of course, I haven't taken it past 30 degrees either. I believe the gear is replaceable. I haven't tried to remove it on my mill. And I'm sure W-I stocks that gear, too at not too bad of an price.You were right the cavity was full of shavings and someone must have tried to turn it withoutView attachment 244246View attachment 244247View attachment 244248 loosing the the bolts
