- May 3, 2020
- 229
Whatever you think---bigger than that. That's always been my experience with electrical enclosures. Oh, and consider getting a label maker that can do heat shrink.
Hi Jim,Maybe build one. I would not go with less than 24x24x12, shorting yourself on panel real estate is a bad idea. Amazon may have some good deals, that's where I buy most of my enclosures these days. Also look at AliExpress.
This is a 24x20 back panel. Way too small for this hardware, but it's what I had on the shelf and also fit in the space I had to put it.
My lathe power cabinet.
And my mill panel 30x36
I’m shopping for a label maker that can do heat shrink. Definitely a nice to have tool.Whatever you think---bigger than that. That's always been my experience with electrical enclosures. Oh, and consider getting a label maker that can do heat shrink.
Thank you for the kind words. My pleasure to help out.Hi Jim,
Thank you for the pictures and cabinet info. I have finishing off my list of DMM equipment and related parts to build my 3 axis mill. I am going to wait for all the parts to arrive and lay them out to see if they will fit comfortably in a 24 x 24 area. If they do, I will order the Vevor 24x24x12 cabinet.
I’m impressed with your wiring!
Thank you for your assistance it’s much appreciated.
Kevin
Do you have a recommended heat shrink label maker I should be looking at?I’m shopping for a label maker that can do heat shrink. Definitely a nice to have tool.
