- Feb 2, 2013
- 3,631
As I found out the hard way, and they stick in your clothes and attack at inconvenient moments.The swarf from the nibblers is bad news if found by your feet....
Really? I would think the thinner stainless (like 20 gauge) would get caught by a tooth and do who know's what!? Can a circular saw safely cut this?Any good 7 1/4" circular saw of 12 or more amps and the right blade will work.
I have a 12" bench shear , it's amazing for sheet upto maybe 2mm thick , can do 3mm (1/8th) but doesn't like it much.In my shop I try to have multiple ways to do most cuts, and then test and find the way that work best for the particular job at hand.
Much depends on the size and shape, as well as material.......
For this question, I would consider these and find what works best:
1) metal bandsaw (I'd buy a high-quality blade and ration its use for stainless only)
2) hand shear (like this)
3) metal chop saw (like this)
-brino
Robert
Also forgot to mention, Depth of cut is critical with a circular saw.
