Damaged Scroll Plate, Fix It Or Scrap It?
Bubba says a little duct tape and some JB weld it will be good as new. :laughing:
Once I used JB Weld to do a thread repair on an aluminum motorcycle valve cover. I read a tip online about coating the screw in a thin layer of grease to keep it from binding to the epoxy. It was an unusual size banjo bolt for the oil feed line, so there was no helicoil-type insert available.
A tiny bit of epoxy made it into the oil feed hole and I starved the engine of oil. But I didn't know until I finished my rebuild days later, around 1:00 am. I couldn't wait, as I hadn't had the bike together in months. I fired it up, put my gear on, and rode out into the night.
For about 2 miles. Eventually the assembly lube proved insufficient and the engine siezed. And I got to push my 600 pound bike home for two miles, in July, in my full gear.
I haven't used that stuff much since then. Kind of left a bad taste in my mouth. :(
