my igaging have had good battery life. I do like them.I want to mount a digital caliper to the tail stock of my lathe to make it easy to zero and measure depth when drilling. So I would like to purchase an economical digital caliper, Mitutoyo seems overkill, but I absolutely don't want one that requires a new battery all the time (the battery in my Mitutoyo's seems to last forever) and all the cheapo calipers I have are basically useless because the battery is dead every other time you go to use them.
Suggestions?
I have 2 igauging calipers, one Mitutoyo 6" nearly new, and a Mit 8" that is 13 years old. All of them have greater than 3 year battery life. The igauging ones use CR3032, and the Mitutoyo uses SR44 - don't use LR44 batteries in the MIT, they last about 1/3 to 1/4 as long but cost 75% of a SR44.
The modified caliper functions as a (almost) DRO, and electronic digital gives you features not easily replicated in a dial caliper. You can also use a small, simple, self-contained digital readout (basically a caliper with the head cutoff), which is what installed on the carriage:Is there a reason a dial caliper could not serve ??
