Brown and Sharpe (Dura-Cal IP65) last long enough that I couldn't tell you how long they last - quite a few years between battery changes.Actual real Mitutoyo are the only ones that the cell will last for a very long time.
GsT
They don't eat batteries, what the OP wanted to know, lol+1 on solar Mitutoyos!
Sent from my SM-G715A using Tapatalk
I want to mount a digital caliper to the tail stock of my lathe to make it easy to zero and measure depth when drilling. So I would like to purchase an economical digital caliper, Mitutoyo seems overkill, but I absolutely don't want one that requires a new battery all the time (the battery in my Mitutoyo's seems to last forever) and all the cheapo calipers I have are basically useless because the battery is dead every other time you go to use them.
Suggestions?
I love this idea!!!My homemade caliper/DRO used the cheap chinese calipers. I just went on line and bought some double AAA battery holders, and wired that up to the battery pins in the caliper. Lasted for years, probably closer to a decade without having to change the batteries...
Had to look:I love this idea!!!
what happens I think the cheap ones like h f there is a draw on the battery even its is off the good ones. have very little draw when the unit is off
look around on the net and that's what you will fine .I have a igaging. two years on the same battery
The current draw should be almost zero on or off. Those batteries have very little capacity, and the design needs to be done correctly. Most of the electronics are probably always on in those. The LCD doesn't really draw any power to speak of.I leave my HF calipers on all the time - never turn them off.
I thought this, too. A while back, someone did a current draw test on various LCD calipers and found that ON did consume considerable more current than OFF (don't ask me where I saw this, but it was on one of my machinary forums). But I still leave my calipers on and I still get about a year, even with the higher current draw.The current draw should be almost zero on or off. Those batteries have very little capacity, and the design needs to be done correctly. Most of the electronics are probably always on in those. The LCD doesn't really draw any power to speak of.
Okay, I'll start! I have the cheapest HF ADWH that I picked up around 1998 (or so). It had a SOLAR panel, so I assumed that it was SOLAR (or light) powered. After about 10 years of use, it started to "not" auto darken. Since it was solar powered (I thought), all I had to do was go outside to do the welding. It STILL wouldn't auto dark. WTF?? I had to retrieve my old flip shield helmet to do the welding. Once you have gone with a ADWH, going back to an "old school" helmet is difficult to adjust to.Don't even get me started about my auto darkening welding helmet!
