To be blunt, that is wrong. Torque is NOT directly related to current. By that logic, a typical motor running on 460V would generate half the torque as the same motor running on 230V, since the nameplate current is about 1/2.
Current * voltage / 746 = horsepower. Or current * voltage * sqrt(3)/746 if its is 3 phase. Actual horsepower is related to that by efficiency, and if you want to really get complicated, you throw in power factor (phase angle).
Use the HP = RPM * torque/5252 to compute torque.
If you're comparing the same number of poles, same voltage, then yes, torque follows current.
