All good suggestions thank you. I do have experience with loose plugs. I have spent some time up grading my garage from ONE, and only 1, 2 plug receptacle. EVERYTHING was on extension cords, which is where I was rolling on the ground to drain the compressor tank, it kicked on, my leg was on the plug in, and it arced real bad before the GFI tripped.
So now I have the original outlet, plus 4 quad outlets, 3 x 4 bulb florescent, 3 x 2 bulb florescents, and 2 x 220 50 amp, and 1 220 100 amp plug ins. With new breaker boxes.
