- Sep 28, 2017
- 44
That looks like a strong repair- stronger than epoxy I'm sure
More than likely overkill and ruined an OEM part but at least it's not going to move....
You have the spindle cap nut and drawbar that require two wrenches in opposition (in the absence of a spindle brake), I believe. Is that how you were trying to do it? I have to whack my drawbar with a brass hammer to drive the collet out. A deadblow hammer also works, but not nearly as well. Since there's a shoulder on your drawbar underneath the cap nut, simply threading the drawbar out pushes the collet out of the taper.
-Jon
My 8520 came to me with a little tiny wrench that I use to adjust/manipulate the drawbar. I don't know if it was original with the machine or not -- I am the second owner. I *assumed* it was original and was small in order to limit the amount of torque one could apply. Here's a pic of the wrench:
Also, to loosen the tool holder I also whack the top of the drawbar with a brass hammer. It doesn't take much of a whack, just enough to shake things loose. Then, I hold the tool and unscrew the drawbar with the tiny wrench til the tool drops out..
Meta Key
