- Sep 28, 2017
- 44
Thanks for the detailed response. I agree I'm fairly novice here but the one thing I know how to do is remove and seat collets. I've done it hundreds of times with my round column RF31. In that mill, the spindle shaft is made to use a 22mm wrench to hold the spindle while you loosen the drawbar about 1/2 a turn. I then give the drawbar a whack with a hammer to drop the collet slightly then continue to unscrew the drawbar until the collet comes free and drops into my hand. I fully understand this process and I imagined the process would be the same with this mill. Again, something isn't right.
What I'm telling you and perhaps you can see this clearer by looking at some of my earlier posts, is that my collet was entirely seized in the spindle. I don't have a brake on mine, the previous owner jerry-rigged some custom setup but that's neither here nor there. My collet holder has flat edges so I can hold the collet holder while I tighten the drawbar. The main point of my argument is that it appears as though the collet holder is not seating correctly in the spindle....so when I tighten the drawbar it's bringing the collet holder too far into the taper (for lack of a better description) and causing it to seize. I don't how else to describe it. Like I said, I finally got it out but I'm hesitant to put it back in because of how hard it was to remove. I literally had to beat the living #@$% out of the drawbar to @#%^#% get the collet out. It's not right. Simple taps should work and I'm concerned that perhaps I'm doing something wrong. If you look at the video I posted above you can see that the collet holder appears to not fully seat....it gets caught on the taper....
