- Oct 31, 2016
- 2,655
I used PVC pipe fittings to practice with when I started. Painted it red with a sharpe. The color gives you a visual reference. When the color is gone the thread should be done. The color really helps with internal threads. I still color whatever I am threading. With internal threading I like doing it with the tool bit on the backside because the motion/hand movements are the same as with external threading.
What were you referring to when you mentioned counting turns. When I am threading I touch the work using the cross slide and set the cross slide to zero. I also zero the compound. My depth of cut is with the compound. The compound is never backed out. Only the cross slide. The sequence I use is to engage the half nuts. Make the cut and disengage the half nuts at the end of the thread. Then I back out the cross slide and return the carriage to the starting point. Next I return the cross slide to zero and advance the compound a couple of thousands. Engage the half nuts for another pass. Do this over and over until the thread is done.
Another handy skill is to be able to pick up a thread. Mr Pete has a good video on picking up a thread. And then you have metric threading. The fun and the learning never stops.
Congrats on your successful thread.
