Agree with the above, the vertical space under the spindle or spindle to table height can be very constricting on small mills. The G0758 has less than 9", so if drilling by the time you add a chuck and a drill bit, which will take probably 4-6" of that, and then a vise, taking another 1-2" you have little room left, so any part of significant height, you will end up having to mount it to the table which is more difficult and time consuming.
Even my little Sherline mill has 12" spindle to table.
At $1900 I'd give a good hard look at something like a G0704 or the similar Precision Matthews PM25 which would only be $400-500 more. You will get a lot more mill for the extra money.
If space requires a smaller bench mill, oddly you might look at the smaller G0781 which although a smaller mill has a few more inches under the spindle (11-1/2" vs 8.75") and it is almost $700 cheaper.
Little Machine Shop also offers some mills in the same general size class
LMS milling machines
