- Dec 27, 2014
- 4,059
Hmmmm...OK.Nothing, the intent is to have the spindle revolve independently of the main-body. It is on 2 bearings intended to let that happen.
You are the 'main body'. The MOST important dimension there is the needle bearing's back (front bearing) to the rear-most location. The needle bearing thickness has the +/- 3 thou because if you're too long you end up hitting the spindle.Drawings look easy enough to follow. Which one should I be looking at making? I'll pay extra attention to it.
Yes, that is correct.The 3 bore diameters result in a through hole, right? Doesn't look bad at all. When we get ready to go, please post the 3D model. It helps to be able to turn it around and look from all sides.
ON the left bar (at least during design in the normal files) there is the ability to disable each component 1 by 1.FreeCAD can do it too. Fusion is nicer though because you can view only the part you want to see. I could have missed an option in FreeCAD. Anyway, looks good.
